Phase detector of the HMC807LP6CE does not work - 2
To Marty Richardson
Hello Marty,
Thank you for your help. Could you help a bit more?
I've attached here the loop filter schematic. Our carrier frequency is 12800 MHz and the REF frequency is 10 MHz. I put the register writting sequence below.
On PowerUp I write:
Register 6
0x0D08, 0x450E
Register 3
0x0600, 0x0A00
Register 9
0x13F8, 0x0000
Register B
0x1600, 0x10F4;
After reset I write:
Register 0
0x0000, 0x0002;
then I write the same that on PowerUp
Thanks in advance,
best regards, Dmitry
Parents
  • +1
    on May 6, 2019 4:33 PM over 1 year ago
    Hi Dmitry,
    You really should write all registers at power up to initialize them to a known state. When doing so please follow the proper sequence as shown in the evaluation board register files (the sequence listed above is incorrect).
    • I may be able help if you can confirm the comparison frequency.
    • I've attached an FAQ which may help in the meantime.
    PDF
    Marty
Reply
  • +1
    Hi Dmitry,
    PDF
    Marty
Children
No Data
