Said in the HMC984S data sheet:Frequency Range is DC to 350 MHz.However, the frequency of the phase detector below is only 175MHZ. So how to understand the maximum frequency of 350MHz in the manual?Can the HMC984 work normally at 200MHZ?
HMC984
Last Time Buy
HMC984LP4E is a high-performance, ultra-low phase noise, SiGe BiCMOS Phase-Frequency Detector and Charge Pump targeted to be used together with the HMC983LP5E...
Datasheet
HMC984 on Analog.com
The HMC984 will work with a 200 MHz reference input but you must set R=2. This insures the PFD comparison frequency (100 MHz) will not exceed the 175 MHz limit.(assuming integer mode with 12 dBm sine wave reference signal).
thank you.Can I set R=1 but reduce the sine wave input power to 5dBm?
No - reducing reference input power lowers the maximum PFD operating frequency. No combination of operating mode or reference input power level guarantees the PFD will run at 200 MHz.
