Help selecting the RF power detector/controller
I am designing a broad band 40 dBm power amplifier (PA) in the frequency range of 0.5-2.5 GHz. I would like to implement Automatic Gain Control (AGC) to precisely control the output power of the PA. After much research, I decided to use HMC1120, mainly because from the RMSOUT vs. Pin diagram (as shown below), it appeared to me that HMC1120 offers consistent RMSOUT for my frequency range of 0.5-2.5 GHz and also good sensitivity. (I understand that I need to convert the RMSOUT with something like AD8062 to provide a negative loop for AGC).
When I started looking for variable gain amplifiers (VGA), the ADL5330 appeared to be an attractive choice. However, going through the datasheet, I noticed that the example shown in Figure 37 of the ADL5330 datasheet (shown below) has used AD8318 for detecting the power in AGC.
I started exploring the AD8318 datasheet and noticed that Figures 42 and 43 of the datasheet shows a similar diagram.
AD8318 also appeared to offer consistent Vout for my frequency range but obviously the slope is negative and this will eliminate the need for converting the slope:
More research led into the Figure 44 of the ADL5513 datasheet, which also offers consistent Vout for my frequency range (as shown on page 8 of the data sheet)
So, now I am confused as to which components to use. Here are my questions:
1) Can you please explain which component I should use in my design (HMC1120, AD8318, or ADL5513) and why?
2) As to VGA, can I use ADL5330 to cover the frequency range of 0.5-2.5 GHz? Is there a better choice that I should look into?
3) I am planning to use a directional coupler at the output of the PA, and then connect the coupler (with correct attenuation) to the HMC1120 to monitor output power. In addition, I need to use a gain stage between my PA and ADL5330 to provide sufficient input for my PA.  That is, I will have three "stages" or "modules" in my control loop. Would the same control loop --such as the one shown in Figure 42 of the AD8318 datasheet-- work stably in my configuration? (In all examples --such as Figure 42 of the AD8318 datasheet-- the AGC is a single stage.).
Thanks again for your help.
    on Nov 6, 2018 1:46 AM over 2 years ago in reply to mazdak@tracematters.com
    Generally not, provided that longer settling time is acceptable for power settings down at the low end. Conversely, if detector is linear-in-dB, and VGA is linear in dBs-per-Volt, then transient response holds consistent across the full power setting range.
  • I think I am now confused! Here are more questions:
    0.5 to 10W is 13dB range, which is considered fairly wide range for a linear-in-Volts-per-Volt detector.
    I am not sure if I fully understand as to why 13dB is considered a "fairly wide range"? ADL5511 has Input power dynamic range of 47dB. So, 13dB would be a fraction of that. Can you please clarify?
    The advantage of accuracy up at the top end of the range will become degraded over 13dB range.
    Lets say my output is 0.5 to 10W (27 to 40dBm). This range can be translated with the help of a fixed -30dB attenuator to -3 to 10dB range, which falls in the linear range of ADL5511 (see Figs 4 and 7 of ADL5511 datasheet rev D). I am not sure if I fully understand as to why you say the top end will become degraded. Can you please clarify?
    We cannot choose the detector without knowing how much amplitude detection range is needed. Please specify if known. You may wish to consider the AD8317 Log detector/controller, if 55dB detection range is acceptable.
    Do we need power detection or amplitude detection? (This is a RF power amplifier to produce RF power (not for signal) and there are no modulations). Therefore the peak voltage and the power are correlated. Also, isn't my range 13dB?
  • Also, will you be able to share the sys-parameters files? I am doing some simulations in Genesys and plan on importing the parameters. Thanks.
    on Nov 7, 2018 2:53 AM over 2 years ago in reply to mazdak@tracematters.com
    Hi mazdak,
    Sorry for the confusion. Lets see if we can clarify:
    The linear-in-Volts-per-Volt detectors don't implement the log function. They tend to be most accurate when driven at a high level on the response curve, but always well within the Abs. Max. rating. For power leveling application with an ADL5511, the rms output is recommended. Datasheet figures 19, 21, and 26 show the approximate temp drift and part-to-part variation.
    Regarding pwr vs amplitude, devices such as ADL5511 respond to amplitude, but we often take measurements relative to a known input power, with RF input impedance-matched. This is what you see in datasheet. A true power measurement would require a directional coupler, to separate reflected wave from incident wave.
    on Nov 7, 2018 2:55 AM over 2 years ago in reply to mazdak@tracematters.com
    Sorry, Analog Devices does not provide a system level or behavioral model for ADL5511.
