I'm looking to use either the ADRF5250 or more likely HMC7992 in a switched RF system and need to know the maximum switching rate the switches will tolerate. I can see the RF rise and fall times and RF switch delay in the data sheets but wonder if there is also a maximum switching frequency that is less than these parameters imply. (This is sometimes the case with RF switches from other vendors who stipulate kHz rate max switching frequencies).
Thank you, Eddie
