ADPD1080 in float mode for very low light measurement
Category: Datasheet/Specs
Product Number: ADPD1080
I'm having to measurie very low reflected light levels but at sample frequency of  about1200 Hz.
I'm struggling to maintain the sampling speed high enough while getting sufficient dynamic range. I've been using normal mode initially but came to conclusion that despite turning TIA gain to 200kohm, integrator gain to 400kohm and pulling few other stops, I would need to increase the number of pulses too high a number to get the dynamic range desired causing the sample speed to drop.
So, I changed onto float mode. All well, except still not enough.
Question: Should it work to have the 4-pulse configuration (masked pulse - led pulse - led pulse - masked pulse) such that only one pulse is masked in order to get 50% extra LED exposure time? I tried that by changing the maths registers to add 3rd and 4th pulses as well as pulse 2. I obviously changed the led firing sequence to contain led being fired on all of the pulses except the first one. The result was that about 10000 got added to the baseline but no other apparent improvement. I have virtually no ambient so I think one pulse measurement on that would suffice as long as I get the other originally masked pulse in good use.
Are there any other stops I can pull in float mode to improve dynamic range?
Thanks!
