MAXIMUM RESOLUTION SUPPORT IN SINGLE MIPI OUTPUT PORT OF AD-GMSL792MIPI-EVK
Product Number: AD-GMSL792MIPI-EVK
I am using the AD-GMSL792MIPI-EVK kit, which has two MIPI output ports. I want to connect two 4K 60 fps YUV422 8-bit GMSL3 camera Systems to both inputs and take the output from a single MIPI output connector. Is this possible?
Please clarify the following queries:
  1. Can we connect two 4K 90 fps GMSL3 cameras and take the output through two separate MIPI output connectors?
  2. Can we take the output of one 4K 90 fps camera through a single MIPI output port?
  3. Is there any possibility of taking the output of two 4K 60 fps YUV422 8-bit cameras through a single MIPI port?
Nitheesh
  • Hi  ,
    Using a 4K (3840x2160) at 60fps (YUV422 8-bit format) stream is feasible for the GMSL3 link as the total rate is ~8 Gbps. But, as the MIPI D-PHY 1.2 supports only up to 2.5 Gbps per lane and the version put in the MAX96792A uses a 4-lane D-PHY interface, the max. is ~10 Gbps for a single output interface. In the first case, the MIPI D-PHY 1.2 outputs supports only up to 10 Gbps, so a 4K at 90 fps, with ~12 Gbps would exceed the 4-lane D-PHY 1.2 configuration. In case of the third question, two 4K at 60 fps will result in a total rate above the maximum one for a 4-lane D-PHY interface. The short description of the evaluation kit is in the following wiki page - AD-GMSL792MIPI-EVK — System Level Documentation documentation.
    Alin
    Please clarify the below queries.
    1. Can I take the output of two 4K 30 fps [YUV422 8 bit] cameras through a single MIPI output? Is this possible?
    2. Can I take the output of a single 4K 60 [YUV422 8 bit] fps camera through a single MIPI output?
    Nitheesh
    To see the throughput supported by using specific configurations, the bandwidth calculator feature of the GMSL SerDes GUI can be used. This is in the tools/status tab. This is useful when having a video input of ~full GMSL3/2 link (12/6 Gbps) and is based on the D/C-PHY options and throughput/number of lanes. An approximate calculation of the input video for the YUV422 format is: frame width x frame height x 16 x FPS bits/s (16 being the number of bits per pixel).
