Sorry for the repeated posting,
I'm having some troubles with my CN0565 measurements board. When running cn0565_prod_tst in the included examples i get the following outputs:
Hi AJollymore ,
- Michelle
Hi Michelle,
The current hardware setup is the adicup3029 with the cn0565 mounted on top, with the breakable resistor array to the electrodes.
Alex
Hi AJollymore ,
May I ask whether you have already made any modifications to the breakable resistor array? If not, could you also provide the board serial number so I can review the production test results?
Additionally, please send a photo of your current setup, as well as photos of the individual boards, so we can proceed with the physical analysis.
Michelle
It looks like only one reading in the production test is failing - might be a good reality check to measure those components with a multimeter and see if they were assembled properly.
Hi Michelle And Mark,
Sorry for the late response, the board now seems to be passing the test, might've just been a tolerancing issue. Serial No. was 08-074522
Alex Jollymore
