Below is my requirement of RF Signal Transmission on Fiber
Core Function
Transmit 100MHz RF signals over 1550nm optical fiber
2mW optical output power with ±5% stability
Key Constraints
No bias tee: Direct RF+DC summing on PCB is preferable than any external summing module
No TEC: Passive thermal management only, application doesnt require one
Single PCB solution: Fully integrated design, most preferablly
Is there any solution done like this from ADI , i could not find any reference design also
I was sucessful in designing RF Rx and TTL Rx, and TTL Tx with help of ADI solutions and complete analog chain, but sending RF over Fiber is little tricky part i am stuck and need some reference
NOTE: Here the signal is RF not a TTL or LVDS like in most reference designs i see are around LIDAR or Optical Gbpgs Transmitters
