Hi, Can I use the Eval Kit with 5VDC Input? If possible, What will be the maximum current required for CN0359 Eval Kit with 5VDC Input?
Hi Vijay016.
Yes, you can use a 5VDC supply since the operating voltage of the EVAL-CN0359 board ranges from 4-7VDC.
Also, there is no benchmark for the required maximum current, but for a 5VDC input, a 3A input current is recommended.
Andy
Hi Andieo, Thank You
Just a note, we recommend using a power supply which is equivalent to this one - EVAL-CFTL-6V-PWRZ Evaluation Board | Analog Devices (note it says max of 3A)
