These devices are designed to test Lithium ion batteries. I am planning to design a lead acid battery analyzer. (lead acid 12v) Is it possible to use these development boards to test lead acid batteries as well? Will it give an accurate data set of internal impedance of lead acid batteries as well? If that's the case, Does the same configuration work or should i amplify the Test signal for it to pass through the lead acid battery. (12v 50AH,60AH, etc.. )
