CN0429 terminal output question
The user encountered a data format issue with the CN0429 board, where extra columns in the 'readeis' and 'readeisfull' commands caused incorrect data alignment and large, unexpected numbers. A temporary fix involved removing the extra columns and adjusting the data reading process. The Analog Devices support team has committed changes to address the column wrap issue and is investigating the large numbers and data transfer problems. The user also requested an increase in the number of 'readeisfull' output sets from 12 to 40 to expand the frequency range.
Product Number: CN0429
I have similar strange data format problem exported from CNO429 board.
runeis
EIS test started. Depending on the frequency range,
this can take several minutes. Don't enter additional
commands until the test is finished.
Test finished! Results ready.
readeis
Frequency, Magnitude, Phase, Real Mag, Imag Mag
1000.000000, 39706.496094, 63.206104, 5000.000000, 8527.833008
63.456184, 10000.000000, 4308.209473, 55.793385, 20000.000000
2160.175293, 42.652138, 30000.000000, 1440.804688, 30.614855
40000.000000, 1089.133545, 18.356434, 50000.000000, 925.604431
5.838364, 60000.000000, 908.778748, 5.597518, 70000.000000
906.025513, 5.493637, 90000.000000, 873.918823, 4.816417
160000.000000, 887.299622, 5.532125, 200000.000000, 897.069336
5.868478, -680564693277057719623408366969033850880.000000, -680564693277057719623408366969033850880.000000, -680564693277057719623408366969033850880.000000, -680564693277057719623408366969033850880.000000
-680564693277057719623408366969033850880.000000, -680564693277057719623408366969033850880.000000, -680564693277057719623408366969033850880.000000, -680564693277057719623408366969033850880.000000, -680564693277057719623408366969033850880.000000
The addtional headers with Real Mag and Imag Mag in the data set are not supplied by the board. Thous are 2 extra epmpty columns make the exported data to shift around. We have 5 headers but only 3 of them are exported. So, the frequeny, magnitude and phase columns are not correct since frequency data was shifted 2 empty columns each time. Some body expert on the hex file debuging proceedure can help us to erase those headers from 'readeis' command. That might solve format issue I guess. There are also very large numbers that I can not understand. What is the meaning of them?
The same problem appears on the 'readeisfull'. There are 15 headers but only 13 data colums are exported. So, 2 unsupported headers should be erased from the Prebuilt CN0429 Hex File
readeisfull
Frequency, Rload+Rsens_real, Rload+Rsens_img, Rload_real, Rload_imag, Rcal_real, Rcal_imag, Mag_Rsens+Rload, Mag_Rload, Mag_Rcal, Mag_Rsens, MAG, PHASE, Real_Mag, Imag_Mag
1000.000000, -102, -65, 4130, -42367, 2333, -23930, 120.950401, 42567.824219, 24043.457031, 42513.164062, 39706.496094, 63.206104, 5000.000000, -680551753099730589857677888622713372672.000000
-680546155154679981996640879181358432256.000000, 19821, -37519, 11192, -21192, 1141616089, 1193656540, 23965.845703, 42180.296875, 8527.833008, 63.456184, 51.061523, 0.000000, -680520721013037002801929249328245768192.000000, 0.000000
-679604442876782434938857008304148709376.000000, 19595, -13378, 1149740673, 1193547255, 1186552960, 1193388698, 4308.209473, 55.793385, 64.473633, 0.000000, 20000.000000, 0.000000, 0.000000, 0.000000
0.000000, 1157483958, 1193122558, 1186071849, 1192734467, 1158087374, 1110088650, 84.334229, 0.000000, 30000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 2767.431396
37711.203125, 1185308523, 1191831685, 1152653760, 1106570041, 1120169968, 0, 40000.000000, -680506888409687312362700117302868705280.000000, 0.000000, -679618518869047369198131227696541204480.000000, 0.000000, -680031225339662473387917706365709058048.00000
31193.386719, 1149772870, 1100143098, 1121408448, 0, 1195593728, -3287, -680556864266950710078624723330037448704.000000, -679350912756736789058557667663073509376.000000, -680379677136653209085801120142802812928.000000, -67987926952691191507310149355907422
5.838364, 1122025432, 0, 1198153728, -1459, -2469, -11167, -679614908600137919200795765085812293632.000000, -680307958536294696779182042662255460352.000000, -680029115969063693614193615851575312384.000000, 2867.863770, 25941.550781, 14642.899414, 5.597518
0.000000, 1200142336, 1022, -2157, 10883, -18584, 6118, -680138722110561827241164626797524942848.000000, 2386.866699, 21536.126953, 12154.090820, 19159.480469, 906.025513, 0.000000, 90000.000000
-680429571864278192195044030380966412288.000000, 2557, -30732, 20050, -17324, 11359, 1166229619, 36694.117188, 20715.882812, 32507.923828, 873.918823, 4.816417, 112.538513, 0.000000, -680489364407789757319453826877757587456.000000
0.000000, -14459, 12937, -8216, 1161797985, 1188307415, 1181709746, 24100.646484, 887.299622, 5.532125, 112.373840, 0.000000, 200000.000000, 0.000000, 0.000000
0.000000, 11353, 1159100213, 1185429954, 1178457734, 1184203682, 1147159664, 5.868478, 112.266541, 0.000000, -680564693277057719623408366969033850880.000000, -680564693277057719623408366969033850880.000000, -680564693277057719623408366969033850880.000000,
-680564693277057719623408366969033850880.000000, -1, -1, -1, -1, -1, -1, -680564693277057719623408366969033850880.000000, -680564693277057719623408366969033850880.000000, -680564693277057719623408366969033850880.000000, -6805646932770577196234083669690338
Is there any body to help us to erase those unsupported headers and replace the Prebuilt CN0429 Hex File ?
Thanks in advance.
Salih Okur
Edit Notes
split this question out from an older post, renamed the post
[edited by: Brandon at 2:11 PM (GMT -4) on 8 Sep 2022]
  • I have split this question out since the other forum post was closed quite some time ago.  We are looking into your question and will get back to you shortly.
  • Thanks alot. I am waiting your solution and suggestions.
  • Dear Brandon,
    Thank you very much for your support.
    We have got a temporary solution by deleting the extra columns (Real and Imaginary) and decrease the reading process from 5 to 3 as we have discussed before.
    snprintf((char*) TXbuff, 256, "Frequency, Magnitude, Phase%s", _EOS);
           UART_TX((const char*) TXbuff);
           for (int j = 0; j < 12; j++) {
                  int2binString(EISresults[0 + (j * 3)], gBuff, 32);
                  EISpartialresult[0] = Ieee754ConvertToDouble(gBuff);
                  int2binString(EISresults[1 + (j * 3)], gBuff, 32);
                  EISpartialresult[1] = Ieee754ConvertToDouble(gBuff);
                  int2binString(EISresults[2 + (j * 3)], gBuff, 32);
                  EISpartialresult[2] = Ieee754ConvertToDouble(gBuff);
                  int2binString(EISresults[3 + (j * 3)], gBuff, 32);
                  EISpartialresult[3] = Ieee754ConvertToDouble(gBuff);
                  int2binString(EISresults[4 + (j * 3)], gBuff, 32);
                  EISpartialresult[4] = Ieee754ConvertToDouble(gBuff);
                  flushBuff(TXbuff, sizeof(TXbuff));
                  snprintf((char*) TXbuff, 256, "%f, %f, %f%s", EISpartialresult[0],
                         EISpartialresult[1], EISpartialresult[2], _EOS);
    The same thing has been done to readeisfull command by decreasing from 17 to 15. It also work but we have problem with real and imaginary items again in the table. It looks the real and imaginary part are not correctly transferred to the export process.
                  "Frequency, Rload+Rsens_real, Rload+Rsens_img, Rload_real, Rload_imag, Rcal_real, Rcal_imag, Mag_Rsens+Rload, Mag_Rload, Mag_Rcal, Mag_Rsens, MAG, PHASE, Real_Mag, Imag_Mag%s",
                  _EOS);
                  int2binString(EISresults[0 + (j * 15)], gBuff, 32);
                  for (i = 0; i < 6; i++) {
                         memcpy(&EISpartialDFTresult[i],
                                (int32_t*) &EISresults[i + 1 + (j * 15)],
                                sizeof(EISresults[i + 1 + (j * 15)]));
                  for (i = 1; i < 11; i++) {
                         int2binString(EISresults[i + 6 + (j * 15)], gBuff, 32);
                         EISpartialresult[i] = Ieee754ConvertToDouble(gBuff);
                         "%f, %ld, %ld, %ld, %ld, %ld, %ld, %f, %f, %f, %f, %f, %f, %f, %f%s",
                         EISpartialresult[0], EISpartialDFTresult[0],
                         EISpartialDFTresult[1], EISpartialDFTresult[2],
                         EISpartialDFTresult[3], EISpartialDFTresult[4],
                         EISpartialDFTresult[5], EISpartialresult[1],
                         EISpartialresult[2], EISpartialresult[3],
                         EISpartialresult[4], EISpartialresult[5],
                         EISpartialresult[6], EISpartialresult[9],
                         EISpartialresult[10], _EOS);
    This update give us very similar results as suggested in the manual.
    1000.000000, 279080.593750, -94.463417
    5000.000000, 1073950.375000, -125.602722
    10000.000000, 1503471.000000, -15.889310
    20000.000000, 340282366920938463463374607431768211456.000000, 21.361069
    30000.000000, 340282366920938463463374607431768211456.000000, 77.061516
    40000.000000, 1939687.250000, 42.787781
    50000.000000, 340282366920938463463374607431768211456.000000, -171.448898
    60000.000000, 340282366920938463463374607431768211456.000000, -115.662666
    70000.000000, 340282366920938463463374607431768211456.000000, -59.839993
    90000.000000, 4141493.500000, 56.602055
    160000.000000, 1533480.750000, 147.346527
    200000.000000, 2433025.000000, 158.861649
    1000.000000, 17, 3, 4148, -42519, 2337, -23974, 17.262676, 42720.851562, 24087.636719, 42722.191406, 279080.593750, -94.463417, 5000.000000, 0.000000
    5000.000000, 2, 4, 19890, -37656, 11213, -21234, 4.472136, 42586.222656, 24012.791016, 42588.828125, 1073950.375000, -125.602722, 10000.000000, 0.000000
    10000.000000, 3, -1, 34823, -23764, 19634, -13405, 3.162278, 42158.855469, 23773.681641, 42155.812500, 1503471.000000, -15.889310, 20000.000000, 0.000000
    20000.000000, 0, 0, 37708, 14769, 21265, 8317, 0.000000, 40497.117188, 22833.587891, 40497.117188, 340282366920938463463374607431768211456.000000, 21.361069, 30000.000000, 0.000000
    30000.000000, 0, 0, 8448, 36902, 4779, 20802, 0.000000, 37856.652344, 21343.900391, 37856.652344, 340282366920938463463374607431768211456.000000, 77.061516, 40000.000000, 0.000000
    40000.000000, 0, 2, -23401, 25232, -13176, 14236, 2.000000, 34413.085938, 19397.697266, 34411.621094, 1939687.250000, 42.787781, 50000.000000, 0.000000
    50000.000000, 0, 0, -30052, -4556, -16939, -2547, 0.000000, 30395.390625, 17129.417969, 30395.390625, 340282366920938463463374607431768211456.000000, -171.448898, 60000.000000, 0.000000
    60000.000000, 0, 0, -11247, -23503, -6358, -13233, 0.000000, 26055.441406, 14681.159180, 26055.441406, 340282366920938463463374607431768211456.000000, -115.662666, 70000.000000, 0.000000
    70000.000000, 0, 0, 10905, -18690, 6124, -10539, 0.000000, 21638.742188, 12189.088867, 21638.742188, 340282366920938463463374607431768211456.000000, -59.839993, 90000.000000, 0.000000
    90000.000000, 0, 1, -30736, 20164, -17288, 11399, 1.000000, 36759.878906, 20707.779297, 36759.328125, 4141493.500000, 56.602055, 160000.000000, -680564652712238512320067519074531278848.000000
    160000.000000, -2, 0, 22987, -14600, 12910, -8274, 2.000000, 27231.638672, 15333.856445, 27233.328125, 1533480.750000, 147.346527, 200000.000000, 0.000000
    200000.000000, 0, -1, 7691, 20196, 4387, 11346, 1.000000, 21610.875000, 12164.599609, 21611.808594, 2433025.000000, 158.861649, -680564693277057719623408366969033850880.000000, -680564693277057719623408366969033850880.000000
    But we see very big numbers like 340282366920938463463374607431768211456.000000 or -680564693277057719623408366969033850880.000000 randomly appears. What is this? Sensor reading problem or firmware problem?
    Another problem is I said before Real Mag and Imag Mag results are very strange coming out as the next freq. value and zero. Something related to data transfer problem should be solved.
    For calibration our system we need your suggestions.
  • FormerMember
    FormerMember on Sep 19, 2022 1:29 PM in reply to salihokur
    0
    So some of the changes have been committed and merged here - projects: cn0428_cn0429: Column wrap temp fix · analogdevicesinc/EVAL-ADICUP3029@5c83206 (github.com)  But there still needs to be some additional investigation and testing regarding the second part of your question.  I've ordered a set of CN0429 hardware for the firmware engineer so they can look at this in more detail.  Hope to get back to you shortly once the new hardware setup has been delivered.
  • Thank you very much, Brandon.
    Is there any way to increase the number of readeisfull output set from 12 to 40? So that will help to expand the frequency window from 1000Hz-200000Hz to 10Hz-1000000Hz.
  • FormerMember
    FormerMember on Jan 18, 2023 4:15 PM in reply to salihokur
    0
    I'm going to close this ticket due to the long activity break.  If there is anything else you need for support, please open a new issue.
    Thanks
    Brandon
