Dear developer of ADI
I am testing the "ADICUP360" and "ADXL355_PMDZ" with "https://github.com/analogdevicesinc/EVAL-ADICUP360" using CrossCore Embedded Studio.
(I would like to call the open source in "https://github.com/analogdevicesinc/EVAL-ADICUP360" as git source).
I found the "SysTick_Config (SystemCoreClock / TIMER_FREQUENCY_HZ)" in Timer.c. of git source.
I also found "SystemCoreClock = SYSTEM_CLOCK = __HFOSC = (16000000UL) /* Oscillator frequency" in system_ADuCM360.c of git source.
I could also find "HFOSC is a 16 MHz internal oscillator that is used in active mode" in "ADuCM360/ADuCM361 Hardware User Guide".
For "TIMER_FREQUENCY_HZ", I could find the definition of "TIMER_FREQUENCY_HZ = (1000u)" in Timer.h.
However, I can not find the exact meaning of "TIMER_FREQUENCY_HZ" and the reason of using "1000u" for this.
I would appreciate it if you could tell me the exact meaning of "TIMER_FREQUENCY_HZ" and
the reason for using (1000u) as the setting value of "TIMER_FREQUENCY_HZ".
