Hi ADI Expert,
Is normal to see pulse / leakage at ADM1085's ENOUT ?
Due to ENOUT is open-drain and this pin is puled high to Vcc.
So before ADM1085 finish initial setting, ENOUT will rise with Vcc.
I also found a describtion in AN-1080 :
"In a system where a brief pulse of the first supply, during initial power-up, does not cause any problems, it is recommend to use VIN only for the circuit supply."
