LTC3633a has provision for feeding in an external clock (MODE/SYNC pin), and also a pin to set a fixed frequency clock with a set resistor (RT pin). I would like to feed in a spread spectrum clock to the MODE/SYNC pin to try to spread noise out over a greater frequency range and I would like to know what should be done with the RT pin in this case as I cannot tell from the datasheet (attached)
Please advise in this regard, or if I have missed something in the datasheet please let me know.
Thanks!
