Hello, I would like to ask for advice regarding an issue I am experiencing.
I am using a circuit based on the typical application of the ADP1031 and AD5758, but I am observing undesirable behavior of the PWRGD signal when a large output current step is applied.
Schematic
Too high current step...
Description of NOK oscillogram:
1. Transient -24 to 24 mA output current from AD5758 (100 R load)
2. Fast load change of VOUT3 and increased voltage on its output around -27 V (measured in AC mode -3 V).
3. PWRGD goes into LOW state, probably because -27 V is threshold 112.5 % from nominal -24 V.
4. After that board's FW react to LOW on PWRGD and writes 0 mA to DAC.
5. PWRG comes back to HIGH because voltage is in desired range.
6. Lastly board's FW (delayed) has PWRGD HIGH and writes 24 mA again to the DAC. Then everything is stabilized.
OK current step -24 to -17 mA...
So, if there is applied smaller step it's ok. Therefore, it appears that the typical application circuit may not be designed for such large load transients. Is this assumption correct?
Possible solution is filtration PWRGD in FW because output current is still perfectly regulated, but I would like to know if it's a feature or wrong implementation on my side.
Edit Notes
formal corrections[edited by: Tomsik at 12:43 PM (GMT -5) on 3 Nov 2026]
