The datasheet recommends tying PGOOD to the 3.3V output of the internal LDO (INTVCC pin). I want to verify that if I do this, the PGOOD pin will be pulled to ground internally before the output of INTVCC can pull up this open-drain pin to 3.3V via the external pullup resistor. If PGOOD starts to rise before it gets pulled to ground, I would like to know how high the voltage can possibly get - I do not want any startup glitch high enough to turn the other downstream device on. I did a simulation with the LTSpice model but did not see any rise on PGOOD which surprised me since I would think that INTVCC would output 3.3V before the pins gets pulled to ground - mainly because the circuitry that pulls the open-drain FET to ground is most likely power by that internal 3.3V LDO. So I am not sure if I can trust the simulation model or not.
