LTC4357 Gate pulldown VCE
Category: Datasheet/Specs
Product Number: LTC4357
LTC4357 gate pulldown circuit is depicted as a BJT.
I'm expecting some residual VCE (~0.2V) to remain on the gate to source voltage due to the BJT discharge.
What is the maximum VCE of this pulldown? We can take the 0A case when it's discharged as much as possible.
Considering the worst case minimum threshold voltage of the FET, I do not want the FET partially turned on by residual voltage.
Thank you,
Orlando
    Let us check with the chip designer and get back to you.
    Thanks!
    I just heard back from the chip designer. Here is their response:
    Upon detecting a fault, the fast pull-down circuit will activate. The fast pull down provides a low impedance path from GATE to IN to quickly discharge the GATE, turning the external MOSFET off. Once the FET is off, the GATE will be at high impedance. There will be no more current flowing at the internal BJT so Vce will be 0V.
    Thanks!
  • This does not answer the question. The fast pull down will have limitations. Since it is shown as a BJT, the gate to source voltage limitation at the pulldown will be the pulldown transistors collector to emitter VCE sat voltage. I ask because MOSFET thresholds can shift, and I'm trying to understand how much threshold shift is acceptable within my FET. I will estimate a ~0.3V VCE for this pulldown, while accounting for a external pull-down resistor slowly discharging the gate to source between 0.3V and 0V.
