LT8210-1 Average Current Sharing: Can a DAC on the shared IMON bus regulate total current across four converters?
The user inquires about using an MCU-controlled DAC to regulate the total average current in a system of four parallel LT8210-1 buck-boost converters. The final answer states that the LT8210-1's closed-loop load sharing mechanism does not support external control on the IMON bus, making the proposed approach unsuitable. The solution emphasizes that the sharing mechanism is designed for automatic current sharing and cannot be externally biased for total current regulation.
Product Number: LT8210-1
We have four parallel buck-boost converter boards, each using an LT8210-1, supplying a common nominal 28 V output. We would like to retain automatic current sharing while adding MCU-controlled regulation of the total average current.
Each converter has:
- A 2 mΩ inductor-current sense resistor connected to SNSP1/SNSN1.
- A 3 mΩ output-current sense resistor connected to SNSP2/SNSN2.
- An 11 kΩ resistor and 10 nF capacitor from its local IMON pin to ground.
- A 499 Ω resistor connecting its local IMON pin to the common IMON bus.
- Local VC1 compensation, with each VC1 connected through 14.7 kΩ to a common coupling node.
On our control board, an MCP47FEB02A0 DAC, powered from 3.3 V, connects VOUT0 to the common IMON bus through a R, currently 100 kΩ. An independent current sensor measures total output current, and the MCU would use this measurement to adjust the DAC.
Our intended control path is:
**Total-current measurement → MCU feedback controller → DAC → shared IMON bus → four LT8210-1 converters**
The idea is to bias the shared average-current measurement, effectively emulating an additional IMON branch, so that all four converters continue sharing while their total current is regulated. We would also like to disconnect the DAC electrically to return to normal automatic sharing.
With a R = 100 kΩ, we observed only approximately 0–10 mV on the common IMON node while sweeping the DAC. We are checking the actual DAC output voltage and observe that the voltage does effectively change from 0V to 3.3V. With all four boards connected and unpowered, measuring across one 11 kΩ IMON resistor gives approximately 3.1 kΩ, consistent with the parallel resistor paths.
Could you advise on the following?
1. Can externally biasing the common IMON bus provide stable total-current regulation on the LT8210-1, or is the sharing mechanism unsuitable for controlling the common current level?
2. Is the “additional IMON branch” model valid? Would a DAC through a resistor suffice, or would a controlled current source or another interface be required?
3. How would this interact with the voltage-regulation loops, VC1 coupling, and IMON current-limit function? Can it reduce total current below the demand at the nominal output voltage, allowing output voltage to fall?
4. What injection range, impedance, control polarity, and bandwidth would you recommend? Are there restrictions specific to CCM or DCM operation?
5. Is placing DAC channel 0 in its open-circuit power-down state sufficient to restore normal automatic sharing?
6. Is there a recommended circuit, application note, or LTspice example for this arrangement?
Our present shunts measure output current. If this approach is workable, we would also like to understand whether an MCU loop using an independent input-current sensor could regulate total input current through the same IMON interface.
We would appreciate guidance in this matter.
Thank you,
Wilson.
  • Hi Wilson,
    Since the LT8210-1 uses a closed loop, load sharing cannot use an external control on IMON.
  • caugusta,
    Thanks for your replay. Does ADI has an IC that could work for our purpose (adding external control on the IMON/ISHARE pin)?  Our VIN would be between 8 V to 33 V while the output should always be 28 V. The current per DCDC controller should be at least 15 A.
    Best,
    Wilson
  • caugusta,
    Following your confirmation that external control through IMON is unsuitable, we would like to ask whether VC1 provides a supported way to implement an external total-current limit while retaining automatic sharing.
    Our system has four parallel LT8210-1 converters supplying a nominal 28 V bus. Each converter has its own VC1 compensation network, and each local VC1 pin connects through 14.7 kΩ to a common VC1 coupling bus. The IMON sharing network would remain unchanged.
    Our proposed control path is:
    Total-output-current sensor → compensated current-error amplifier → sink-only connection to the common VC1 coupling bus.
    An MCU-controlled DAC would set the current command. Below the limit, the external controller would release the bus. Above the limit, it would sink current to reduce the converters’ combined output current.
    The application is source-power management: we want to reduce the DCDC converter demand when the input source cannot sustain the requested power, potentially an MPPT algorithm. Normal output regulation would remain at 28 V when sufficient power is available.
    Before implementing this, we need clarification on the datasheet restriction: “Do not force voltage on the VC1, VC2, or SS pin.”
    1. Does that restriction prohibit an external controlled current sink on the common VC1 coupling bus, even through the four 14.7 kΩ resistors? If a current sink is permitted, what current, voltage, and power-sequencing limits apply?
    2. Can this arrangement regulate total current while the internal IMON loops continue balancing the four phases, or would the sharing and voltage-regulation loops oppose the external controller?
    3. The datasheet lists approximately 35 µA typical maximum sourcing current for each voltage-error amplifier. During external limiting, would the sink need to overcome approximately four times that current, or are there additional internal current contributions?
    4. If external VC1 sinking is unsupported, what interface or alternative controller does ADI recommend for externally commanded total-current regulation with multiphase sharing?
    We measured VC1 directly at IC pin 8 while the output remained at 28 V. The load currents below are the combined output of all four converters, not per-phase currents:
    Total output current VC1 at VIN = 27 V VC1 at VIN = 33 V
    0 A 0.59 V 0.50 V
    1 A 0.82 V 0.65 V
    2 A 0.94 V 0.72 V
    3 A 1.17 V 0.90 V
    4 A 1.20 V 0.95 V
    These are normal operating measurements without external VC1 control. Our intended operating point is up to approximately 60 A total, subject to input voltage and power-stage capability.
    We would appreciate confirmation that this interface is supported before attempting external VC1 control, and any reference circuit or simulation example you can provide.
    Thank you,
    Wilson
