I am looking for assistance to diagnose the inability of my PCB to drive heavier loads. For simple loads such as a green LED with 330 ohm resistor in series, or even Qty. (4) 330 ohm resistors in series, the PCB drives these loads just fine. For more complex loads such as a Raspberry Pi Zero W or 2W, the LTC7891 does not seem to transition from light-loads to heavy load and drive the load. When a Raspberry Pi Zero W is loaded on the PCB, the output sags to ~3.2V, which includes the output ripple. This is not enough to power the RPi Zero W at we need a resilient 5V supply.
I am using an LTC7891 Buck Voltage Convertor to step down a Vin of 7-17V (nominal 12V) to a Vout of 5.4V pre shottky diode and 5.1V post shottky diode. After manufacturing my boards with JLCPCB, I register 6.38V on an oscilloscope post-shottky diode. Some components were mandatory to be changed due to JLCPCB availability.
A BOM will be shared below:
The Inductor used is a 4.7uH PN:SRR1280-4R7YCT-ND.
The 47uF input and output capacitors are PCV1J470MCL2GS
I will also share my schematic below:
When I measure the SW node, I noticed even though the power supply has an input of 17V, the ringing goes up to 30V where I set the trigger. This seems excessive for this device.
Here are my images of my PCB:
