charge status 32
Product Number: LTC4162-S
Hi I am getting a status on the charge_status of a 32. The power supply voltage is 27.5 volts and the battery are 2 12VDC lead acid batteries in series to generate a 24VDC source. My current motor of the power supply is bouncing from 0 amps to 600ma, then 400ma, then 200ma then back to 0ma. It keeps cycling through this about once a second. This is with no load on the system and I can not talk with the LTC part since that load has been disconnected. My battery voltage on the battery connector to the LTC part is bouncing from 26.xx to 27.xx volts and then cycles every 1 second.
When I add the controller load onto the system, I get a status of 2048, 512 and 256 from the charger_state and a 0 or a 32 on the charge_status.
Is this normal?
regards,
Charles
  • Looking into the schematic here, I just wanted to confirm a couple of things.
    Are you using default charging settings, or did you program different charge voltages? Also does measured voltage at the charger input stay at 27.5V while current cycles?
  • Yes it is set for the defaults. I have been playing more with the our new controller that now has isolator's on the external devices (serial port and power to a another Linus computer). All seems well now and everything is working 100%. What I did to eliminate the problem was raise the external power supply to 32VDC. That solved a lot of problems.
    Thanks and regards,
    Charles
