LT8316 LTspice Model EN/UVLO Issue and 110 W Flyback Application
Hello Analog Devices Support,
I am developing a battery-powered isolated flyback converter using the LT8316 for a high-voltage plasma application.
Our specifications are:
  • Input: 44.8–58.4 V DC (55 V nominal)
  • Output: approximately 6.5 kV DC, 17 mA per converter
  • Output power: approximately 110 W per converter
  • Intended architecture: three isolated converters supplying one 325 W reactor
Our LTspice simulation produces approximately 6.54 kV under a resistive load. However, when EN/UVLO is pulled to nearly 0 V, the MOSFET continues switching.
I found an EngineerZone discussion from March 2024 reporting that this behavior was caused by a bug in the LT8316 simulation model.
Could you please confirm:
  1. Is a corrected LT8316 LTspice model available?
  2. How can we obtain and install the corrected model?
  3. Is approximately 110 W per LT8316 flyback converter a supported application?
  4. Are there recommended reference designs or alternative controllers for this high-voltage application?
I can provide the LTspice schematic and simulation logs.
Thank you for your assistance.
