We have configured our LTC2955-1 with a 1 uF capacitor on TMR for a 5.2 s turn off. After power on, the INT line bounces for long (> 3.5s) push button presses. In the scope shot below, INT is green, PB is blue, and EN is yellow:
Is this characteristic of the chip, or does some filtering need to be applied to one of the lines? The PGD line is floating, ON, EPAD, and SEL are grounded. KILL is attached to an MCU and does not move.
This is our setup, The PB pin runs directly to a MCU with the GPIO line pulled up internally. EN runs to a regulator. Probing the INT pin of the device does display this behavior. It only happens for "long" button presses -- "long" meaning approaching the turn off time programmed into the device, > 3.5 seconds or so.
