In the LTM4624 datasheet, on page 24 under SUGGESTED PCB LAYOUT, the recommended diameter for the BGA land pattern appears to be specified differently in two places: 0.315 mm (diameter = 0.630 mm) at one location and 0.3175 mm at another.
Could you please clarify whether all BGA land patterns should follow a single diameter of 0.315 mm, or whether specific BGA ball land patterns are required to use 0.315 mm while others should use 0.3175 mm?
Please also confirm the recommended land pattern dimensions for each BGA ball type, if they differ.
