Threshold Variation in LTC4368 – Calculated UV/OV Thresholds (7 V / 36 V) vs Measured Hardware Thresholds (2 V / 53 V)
Product Number: LTC4368
We are evaluating the LTC4368HDD-2 in a 24 V protection circuit designed according to the LTC4368 datasheet.
The UV and OV resistor network was calculated using the equations provided in the datasheet with the following resistor values:
  • R1 = 3.9 MΩ
  • R2 = 243 kΩ
  • R3 = 59 kΩ
The intended protection thresholds are:
  • Undervoltage (UV): 7 V
  • Overvoltage (OV): 36 V
These values were also verified through simulation, which produced the expected operating range of 7 V to 36 V.
Measured Observations
  • At VIN = 53 V, the OV pin measures approximately 0.49 V, and the LTC4368 immediately turns OFF the external MOSFETs.
  • During UV testing, the output turns OFF at approximately 2 V input. At the instant of UV shutdown, the UV/SHDN pin measures approximately 0.7 V.
  • I checked your calculations, and they are correct and should work in LTspice.
    In an actual board, you may have issues using resistor values that high due to board contamination.
    I suggest keeping resistor values under 1MΩ to reduce sensitivity.
    Redo your test with the new component values for your divider:
    RTOP=931kΩ
    RMID=57.6kΩ
    RBOT=14kΩ
