I have a question regarding the LT8638S power-up sequence.
Is it supported to drive the EN pin high before VIN is applied?
In my setup, VIN and EN are supplied by two independent 5 V power supplies. I observed the following behavior:
- If VIN is applied first and EN is asserted afterwards, the device starts normally.
- If EN is driven to 5 V first and VIN is applied afterwards, the VIN power supply immediately enters current limit and its output voltage collapses.
The converter is unloaded during this test.
Is this operating sequence supported, or does the LT8638S require VIN to be present before EN is asserted?
Thank you.
