LTM4668A: Alternative Method to Disable 2 out 4 Channels Without RUN Pin Control
Product Number: LTM4668a
LTM4668A QUAD channel output
The LTM4668A  is implemented on the PCB, and I need to disable 2 out 4  output channels.,Since there is no provision to access the RUN pin, is there any alternative way to shut down the  output channels?
NOTE:
  • The signal connected to the RUN pin is also used to enable several other power rails, so I cannot disable that enable signal.
  • Additionally, there is no 0 Ω resistor or isolation provision between the enable signal and the RUN pin, making it difficult to disconnect the RUN pin from the existing control signal.
