Design Review
Product Number: LTC7103
Hello, can you review my design. It's primarily used to take 60V regulated input and charge a 55V battery. I've set the Ictrl to 0.75A and vout to 55.9V to take into account diode drop and other series resistances. It worked well in testing with both the battery and DC load, until an issue happened with the LTC7103 board. It's exhibiting a short and I was curious what could be the root cause. Looking at the datasheet, I don't see where the issue could be. I've simulated it as well on LTSpice
  • Hi  ,
    Thank you for sharing the schematic and test results. One concern is the limited headroom: 60 V input and 55.9 V output corresponds to about 93% duty cycle, placing the LTC7103 close to dropout.
    See note 9 of the data sheet:
    For VOUT above 43 V, the LTC7103 must use the datasheet’s high-output-voltage operating method, including the minimum VIN requirement:
    VIN(MIN) ≥ VOUT / (1 − fSW × 260 ns)
    At 300 kHz, a 55.9 V output requires approximately 60.6 V minimum input, so a 60 V rail does not provide adequate margin. Operation in this region may allow negative inductor current to accumulate during boost-capacitor refresh and could overstress the internal switches.
    Please also confirm that EXTVCC is not connected to the 55.9 V output, since its absolute maximum rating is 41 V, and verify the failed board’s VIN-to-GND, SW-to-GND, and VOUT-to-GND resistances with power removed.
    I recommend increasing input headroom or lowering the output voltage, then programming RUN/UVLO to prevent operation below the calculated minimum VIN.
    Best,
    Douglas
  • Hi Douglas, thanks for the response. I was able to modify the input to be 62V and the output to be closer to 55.6V so that should help. I'm running the converter at 200kHz as well. so I have more good amoutn of margin overall. VIN (MIN) would be  55.6/(1-200e3*260e-9) = 58.65V so I have about ~3.35V headroom.
    EXTVcc is not connected to output and internal LDO operation is used.I've also updated UVLO to be around 58.2V.
    Can you confirm the above changes are all good for no issues on the design?
    Best,
    Mina
  • Hi  ,
    Thanks for the update those changes look like good progress. Here's a quick confirmation of each item:
    Operating point (62 V in / 55.6 V out, 200 kHz): Confirmed good. Duty cycle is ~89.7%, and your V_IN(MIN) math is correct: 55.6 / (1 − 200k × 260 ns) = 58.65 V, giving ~3.35 V of headroom from 62 V. That keeps you out of the near-dropout region.
    EXTVCC open / internal LDO: Correct approach for a 55.6 V output. EXTVCC bootstrapping is only valid for V_OUT between 3.3 V and 40 V (abs max 41 V), so using the internal LDO is the right call here.
    One item to adjust... UVLO threshold: You set UVLO rising to ~58.2 V, but your required V_IN(MIN) is 58.65 V, so the current setting is about 0.45 V too low. Since the RUN-pin divider is what actually enforces the minimum input, a UVLO below V_IN(MIN) still permits start-up/switching in the 58.2–58.65 V window the exact region we want to avoid for the dropout region we encoutered above.
    I'd recommend raising UVLO rising to comfortably above 58.65 V... something like 59.5–60 V gives real margin while still allowing operation from your 62 V rail. Also confirm the UVLO falling threshold stays above 58.65 V; the RUN pin has ~100 mV hysteresis (1.21 V typ rising threshold), so account for that in the divider so it doesn't ride down into the dropout zone during a transient sag.
    I Got this from the datasheet's Pin Functions (RUN, Pin 3) notes where it mentions a resistor divider is used between V_IN and RUN to function as an undervoltage lockout, and the Electrical Characteristics table gives the 1.21 V typ ON threshold with 100 mV hysteresis.
    Once UVLO is nudged above V_IN(MIN), everything should be clear of the failure mechanism. Happy to help work out the exact divider values if useful.
    Best,
    Doug
