Inductor DCR current sensing for LT8292 (instead of discrete shunt resistor)
The user inquired if the LT8292 can use inductor DCR current sensing like the LTC7891. The final answer confirms that the LT8292 does not support DCR sensing due to high LSN pin leakage current, which introduces significant error. A direct current sense resistor is recommended for the LT8292.
Product Number: LT8292
I am using an LT8292 and also a LTC7891 in a design.  The LTC7891 explicitly calls out inductor DCR current sensing as a technique to avoid use of a discrete shunt, as well as a detailed procedure for choosing the corresponding passive components.  The LT8292 doesn't mention that technique in its datasheet.  Can I use the same technique for the LT8292, or is this not recommended for a specific reason?  The inductor DCR (3.8-4.3mOhm) is much larger than the resistance of any shunt I would want to use (~1mOhm) so this would provide a larger signal for the current control.  Obviously the inductor DCR is less precise, but I don't have a sense of how to trade-off these attributes.
Thanks!
Sam
