LTM8049 LTSpice model, share pins configuration
The user asked about the connection of SHARE1 and SHARE2 pins in the LTSpice demo circuit for the LTM8049. The final answer confirmed that these pins should only be connected when using the outputs in parallel; for separate supplies, they should be left floating. The user noted that the demo schematic should be corrected, and the support engineer acknowledged this and informed the product line.
View FAQ
Product Number: LTM8049
The LTSpice demo circuit for LTM8049 has share pins connected: https://www.analog.com/en/resources/design-tools-and-calculators/ltspice-simulator/lt-spice-demo-circuits.html
From datasheet, this should only be done when using outputs in parallel configuration, to enable current sharing.  This is not the configuration of the demo LTSpice schematic.
Although the simulation seems to work, changing load conditions will give bad results.  Removing the share net improves the simulation.
Can you confirm that for this configuration (or other dual rail configurations), the share pins should be connected or not?
Thanks in advance
