Will It Generate 5.5 out from 12V
Product Number: LTM4637
Hello Team,
I have a question regarding the LTM4637 µModule regulator.
I am trying to generate a 5.5 V output from a 12 V input supply. Based on the datasheet, the device supports 5.5 V output with load currents in the range of approximately 10–15 A.
I performed a simulation in LTspice, and while I am able to obtain an output close to 5.5 V, I am seeing some variation, and the output is not stable or exactly at the expected value.
For the feedback network:
  • I adjusted the VFB resistor to ~7.5 kΩ
  • When I reduce the value further, the output does not behave as expected and becomes unstable/misaligned
I would like to understand:
  1. Whether the LTM4637 can reliably generate 5.5 V from a 12 V input under these conditions
  2. If my feedback resistor selection is correct
  3. Whether there are any design considerations that I might be missing in simulation
I have attached my schematic for reference. Kindly review it and let me know if there are any mistakes or improvements needed.
Surya
/resized-image/__size/2776x980/__key/communityserver-discussions-components-files/330/pastedimage1780408772187v1.png
  • Hi  ,
    Can you upload your LTspice schematic, symbol and model files? Zip up and drag to this window.
    mike
    LTspice Team
  • Hi MStokowski,
    Please find the attached image of the LTspice simulation. Here, I am not able to generate the exact 5.5 V; I am getting around 5.4 V
    Surya
  • Hi  ,
    It's best if you upload your schematic files. Drag to the window, or Choose Insert > Image/Video/File and then click upload in window that appears.
    mike
  • Hi Team,
    Please find the attached simulation files for your reference. Kindly review and provide your feedback.
    LTM4637.ascLTM4637.rawLTM4637.op.raw
    LTspice 24.1.8 for Windows
    Circuit: C:\Users\suryaganesh.c\Documents\LTspice\LTM4637.net
    Start Time: Thu Jun  4 14:36:42 2026
    solver = Normal
    Maximum thread count: 8
    tnom = 27
    temp = 27
    method = trap
    Direct Newton iteration failed to find .op point.  (Use ".option noopiter" to skip.)
    Starting Gmin stepping
    Gmin = 10
    Gmin = 1.07374
    Gmin = 0.115292
    Gmin = 0.0123794
    Gmin = 0.00132923
    Gmin = 0.000142725
    Gmin = 1.5325e-05
    Gmin = 1.6455e-06
    Gmin = 1.76685e-07
    Gmin = 1.89714e-08
    Gmin = 2.03704e-09
    Gmin = 2.18725e-10
    Gmin = 2.34854e-11
    Gmin = 2.52173e-12
    Gmin = 2.70769e-13
    Gmin = 0
    Gmin stepping succeeded in finding the operating point.
    Total elapsed time: 4.864 seconds.
    Files loaded:
    C:\Users\suryaganesh.c\AppData\Local\LTspice\lib\sub\LTM4637.sub
    Surya
