LTM4673: Can Channel 1 be enabled by hardware by default at power-up without PMBus configuration?
Product Number: LTM4673
I am using the LTM4673 Quad Output μModule Regulator with Digital Power System Management in a design with the four outputs configured at different voltages.
I would like to enable Channel 1 / VOUT1 automatically by hardware when the board powers up, without having to configure the device through PMBus.
In other words, if I connect CONTROL1 to VDD33 through a pull-up resistor, and VIN/VINSNS exceeds VIN_ON, will VOUT1 start automatically after the default TON_DELAY, assuming the factory default OPERATION
Thank you.
Umberto.
Edit Notes
Title change
[edited by: uv1234 at 10:36 AM (GMT -4) on 22 May 2026]
