LTC3884
Recommended for New Designs
The LTC3884/LTC3884-1 are dual output PolyPhase DC/DC synchronous step-down switching regulator controllers with an I2C-based PMBus compliant serial interface...
Datasheet
LTC3884 on Analog.com
Hi, I am developing new version of existing board, I have to keep power supply for CPU as it is to keep SW compatibility. LTC3884-1 (second output of LTC3884-1) is used for CPU, but I do not need any more other power supply generated originally with this LTC3884-1 (first output of LTC3884-1). Is it ok if I just remove power components (MOSFETs, Indutor, shunt, output capacitorsor) this supply from the layout and disable this output with low RUN1 on pin 17?
Hi pezic,
A great idea to reuse a controller that you've already take time to prove out as we all know how challenging power designs can be.
I checked with the factory team and they noted you can hold RUN1 Low to only use RUN0 and OUT0.
Best Regards,
Chris - Tech Support
Thank you very much for your help.
BR Alenka
Sure thing Alenka and never hesitate to contact ADI for support.
We also have support via this link for both live (phones) and emails.
https://www.analog.com/en/support.html
Best Regards,
Chris
