ADP5014 Vout power sequence
Category: Datasheet/Specs
Product Number: ADP5014
I have checked the forum discussion linked below, and it appears that the resistor value table for the ADP5014 power sequence has been updated there.
ADP5014 VOUT Sequence
However, the datasheet itself does not seem to have been updated accordingly.
Is there a specific reason why the datasheet has not been revised to reflect this information?
At the moment, it is unclear to me which values should be considered correct, and this is causing some confusion.
Could you please advise which values should be used for design?
Kind Regards,
    Thanks for contacting Analog Devices!
    Here is the updated resistor for DL12 and DL34. You can try to use resistor in parallel if you cannot find specific value.
    Datasheet will update soon.
    RDL12
    (or RDL34)
    (kΩ)
    Channel 1 Sequence (or Channel 3)
    Channel 2 Sequence (or Channel 4)
    9.53
    First order
    First order
    0
    First order
    Second order
    11.5
    First order
    Third order
    14
    First order
    Fourth order
    16.9
    Second order
    First order
    20.5
    Second order
    Second order
    24.9
    Second order
    Third order
    30.1
    Second order
    Fourth order
    36.5
    Third order
    First order
    44.2
    Third order
    Second order
    53.6
    Third order
    Third order
    Float
    Third order
    Fourth order
    64.9
    Fourth order
    First order
    78.7
    Fourth order
    Second order
    95.3
    Fourth order
    Third order
    115
    Fourth order
    Fourth order
  • Thank you for the information and the updated resistor values.
    This is very helpful for our design.
    I appreciate your support.
