Reaching 0V with LT3081 - Problem of Error Amplifier Circuit
The user is facing issues reaching 0V output in a PSU design using the LT3081 due to a voltage drop across a 1N4148 diode. The final answer suggests that the opamp's negative power supply should be a few volts below ground, ideally -2 to -3V, to enable the opamp to output zero volts, which is necessary for the LT3081 to achieve 0V output.
Product Number: LT3081
Hello Guys,
I wanna design PSU by LT3081 and i have some problem with integrating voltage and current control with software. i've seen this circuit posted by   and works good but the problem that the diode 1N4148 gives some voltage drop that make me can not reach 0V.
Any Suggestions ?
