LTC4291 and LTC2492 suggested polarity for connection to the transformer center tap
The user inquires about the unconventional DC polarity connection for the LTC4291-1/LTC4292 in PoE designs, where positive supply is connected to pairs B (3 & 6) and C (4 & 5), and the negative to A (1 & 2) and D (7 & 8). The final answer explains that this configuration aligns with IEEE 802.3bt standards for Type 3 and Type 4 PSEs, specifically Alternative A (MDI-X) and Alternative B (S), which support higher power classes. The bridge rectifier in the PD ensures compatibility regardless of polarity.
Category: Datasheet/Specs
Product Number: LTC4292
I am designing in this chipset to a piece of equipment.  Looking at the datasheet, and even other documents, I see it is suggested to connect the positive supply to pairs B (3 & 6) and C (4 & 5).
The switched negative rail is connected to the A (1 & 2) and D (7 & 8) pairs.
www.analog.com/.../ltc4292-4291.pdf
This is not how I see these connections specified outside of a few Linear Tech PSE datasheets.  Most of the documentation (even the LTC4279 datasheet) I see for 802.3 at/af/bt all connect the positive to the A and C paris and the negative to B and D pairs.  I know it should not matter much because the PD should have a bridge rectifier.  I am asking why these parts are suggest the DC polarity be different from the norm.
  • Hello,
    What you're looking for are Tables 145-3 and 145-4 from IEEE 802.3bt. I'll summarize below.
    Table 145-3 defines the different polarity options you listed above:
    • Alternative A (MDI-X) - Positive on 3-6; Negative on 1-2
    • Alternative A (MDI) - Positive on 1-2; Negative on 3-6
    • Alternative B(X) - Positive on 7-8; Negative on 4-5
    • Alternative B(S) - Positive on 4-5; Negative on 7-8
    Table 145-4 states the permitted pinouts by PSE type. Type 3 PSEs, which support up to Class 6 / 51W, may use any of the above pinouts. Type 4 PSEs, which support up to Class 8 / 71.3W, are restricted to Alternative A (MDI-X) and Alternative B (S). That is why the LTC4291-1/LTC4292 documentation suggests connecting the positive supply to pairs 3-6 and 4-5 as that configuration works with both PSE types.
    Best Regards,
    Eric
