Subharmonic Oscillation
Product Number: LTC3786
I am using this controller for my boost converter, LTPowerCAD file attached. Below are my requirements:
Vin = 8.75V, Vout = 12V, Iout = 18.5A, Pout = 220W
However, I am observing a symptom of subharmonic oscillation as shown in the scope shot below. There's no oscillation at no load but observed it when I increased the load, started to observe the oscillation at about ~3A. I tried to use 2.2uH, 3.3uH and 4.7uH inductor to change the inductor slope (since I do not have control on the internal slope compensation ramp) but the symptom is still observed. When I changed the sense resistor to 3mohm (from 2mohm), to increase the gain, with 2.2uH inductor. The symptom disappeared. I believed this is something related to the internal slope compensation. However, with 3mohm sense resistor, I am limited to only 25A current limit. Can you suggest what can be done to achieve the load current of >18.5A? The inductor I used is the XGL1313 series from Coilcraft, which has high Isat
Scopeshot: L = 3.3uH, Rsense = 2mohm, no load
Scopeshot: L = 3.3uH, Rsense = 2mohm, Iout = 17A
12VF 200W 2nd stage.zip
    Here are some practical paths forward:
    1. Sense Resistor Tradeoff
    • Increasing Rsense (from 2 mΩ → 3 mΩ) improves stability because it increases the effective current ramp relative to the compensation ramp.
    • The downside is reduced current limit. If you need >18.5 A continuous, you’ll want to avoid clipping too early.
    Option: Use multiple parallel sense resistors to fine‑tune the effective value. For example, 2.5 mΩ may give you stability without cutting the current limit too much.
    1. Inductor Selection
    • Larger inductance reduces the inductor current ripple, which lowers the sensed slope and makes slope compensation less effective.
    • Smaller inductance increases ripple, which helps stability but increases conduction losses and ripple current stress.
    1. Loop Compensation
    Even though the oscillation looks like subharmonic instability, verify your compensation network. A poorly tuned error amplifier can exacerbate the symptom.
    • Try lowering crossover frequency (reduce bandwidth).
    • Ensure adequate phase margin at high load.
    • Try to reduce Rth -> reduce BW and check it might improve subharmonic oscilation
    Please provide your observations results.
    Harshal
