LTC7000 TS PIN FAILED when connected to load
Product Number: LTC7000
 We are using this circuit to switch 65V for Power amplifer drain ,When Power amplifer is not connected,Voltage is switching as expected but when connected to drain of power amplifier with 1.5A load current,LTC7000's TS Pin,TGUP and TGDN pins are failing and showing 8ohm impedance w.r.t ground.Kindly check the schematic and provide solution
