LT8641 LTspice model: no pulse-skipping in SYNC mode?
Product Number: LT8641
Software Version: ltspice 26
I am using the LT8641 in SYNC mode with an external PWM control.
According to the datasheet, the LT8641 is expected to operate in pulse-skipping mode at light load. However, in LTspice simulations, it appears that the model always operates in Burst Mode instead.
This makes it difficult to accurately simulate my control scheme at light load.
Could you please clarify:
  1. Does the LT8641 LTspice model support pulse-skipping mode, or is it simplified to Burst Mode only?
  2. Is there a way to force SYNC / pulse-skipping operation in the LTspice model?
  3. If not, what would be the recommended approach to simulate light-load behavior more accurately?
Thank you for your help.
Arnaud
  • Hi  ,
    I'm having someone in the modeling group look at it. Thanks.
    mike
  • Hi Arnlej,
    The model should support the Pulse-Skipping mode, I can't really tell if I was able to replicate your simulation set-up results as you have not provided any Figure or Simulation files but here's what I was able to come up to using the Example circuit found in LTspice.
    1. I made sure that the minimum load needed to operate at Pulse-Skipping mode is set. (See Figure below from the datasheet page 14 Figure 2(b)). With a 5V output and an input voltage of 48V the estimated minimum load is around 125Ohms. ( 5V / 0.04)
    2. Tried operating it with the SYNC/Mode Pin floating and it seems to operate at pulse-skipping mode with the 1MHz frequency.
    3. Then I tied the SYNC/Mode Pin with a 1.5MHz PWM and it seems to operate at Pulse-Skipping Mode as well.
    Just a few things to note that it is important to achieve the minimum load requirement to attain Pulse-Skipping Mode.
    Best Regards.
    Earl
  • Hi Arnlej,
    Best Regards,
    Earl
