I'm looking for a negative voltage linear regulator that can output -30 volts at a 100 mA load (max load). Doing some research, I stumbled upon the LT3090 and the LT3091. I ran some simple simulations with the parts in LTspice, using a negative input voltage of -32 volts.
Unfortunately, I found that the LT3090 cannot output -30 volts at 100 mA, despite what the datasheet claims. The dropout voltage is higher than what is recommended in the datasheet, and the current limiting function is turned off. However, when I replaced the LT3090 with the LT3091, using the same components in both circuits, the LT3091 was able to output the correct voltage and the correct current. I've attached the test circuits below. The only difference I can tell between the two ICs are the current limit, but are there any other differences between the two ICs that would cause one to work and the other one to not work properly?
