ICP, ICN current monitor unused termination
The user inquired about the termination method for ICP and ICN pins when current monitoring is not used. The final answer states that floating these pins is acceptable for standalone use of the LT8708, but they should be connected to GND with a 17.4kΩ resistor if used in parallel with other devices. The accompanying answers confirm that the 17.4kΩ resistor is necessary for parallel operation, even if current monitoring is not used.
Product Number: LT8708
Hi Expert,
Could you please let me know about the termination method for ICP and ICN pins, in case of unused current monitoring?
Do you have any issue about floating pin(Open)?
Muk
