Can you please provide the allowable input range (Max and Min) for the PWM frequency that can be applied to the LT3743 IC?
I am observing visible banding in the captured image due to light switching, so I would like to experiment with different PWM frequencies to check whether the banding reduces or disappears.
Currently, I am using a 20 kHz Input PWM signal. The RT resistor value is 100 kΩ, and the MOSFET switching frequency is 400 kHz.
