Difference between the part codes ending in R2 and R7
The user inquired about the difference between ADM7150ACPZ-5.0-R2 and ADM7150ACPZ-5.0-R7. The final answer clarified that both parts are identical 5 V, ultra-low noise, high-PSRR LDOs in LFCSP packages, with the only difference being the tape-and-reel quantity: R2 has 250 units per reel, and R7 has 1,500 units per reel.
Category: Datasheet/Specs
Product Number: ADM7150
I'm planning to use ultra-low noise high-PSRR LDO (ADM7150) in my design.
Following are my basic requirements:
  • Vin = 6.2 V
  • Vout = 5 V
  • Iout = 350 mA
I'm going with LFCSP package instead of SOIC due to better thermal performance.
Accordingly, I have two part codes:
  • ADM7150ACPZ-5.0-R7
  • ADM7150ACPZ-5.0-R2
What is the difference between the parts ending in R2 and R7? I'm not able to see it in the datasheet.
Binayak
  • ADI North America will be on winter shutdown starting December 24, 2024; perhaps another community member can assist you until our return on January 2, 2025.
  • Hi Team,
    The difference between ADM7150ACPZ-5.0-R2 and ADM7150ACPZ-5.0-R7 is purely in the packaging and reel quantityBoth are identical devices (5 V fixed-output, ultra-low noise, high-PSRR LDO in LFCSP package). The suffix “R2” and “R7” indicate different tape-and-reel options used for automated assembly.
    Suffix Codes
    • R2 → Tape-and-reel packaging, typically 250 units per reel
    • R7 → Tape-and-reel packaging, typically 1,500 units per reel
    Tech Support
