I want to know is it okay using VDD18 pin to pull-up source of PGOOD.
Please note that the design is intended for the Vin of 12V and the Vout of 0.75V.
KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
November Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Ever wonder how EMC limits came to be and why they matter? Dive into the interesting bits of EMC limits and levels, then test your knowledge with EMC: The Interesting Bits Quiz.
Read the blog first: EMC Limits and Levels Explained: Well, the Interesting
LT7170
Recommended for New Designs
The LT7170/LT7170-1 are monolithic DC/DC synchronous stepdown
regulators that deliver up to 20 A of continuous output
current. The LT7170-1 option has...
Datasheet
LT7170 on Analog.com
Using the VDD18 pin of the LT7170 as a pull-up source for the PGOOD pin is not recommended. The VDD18 pin is an internal 1.8 V regulator bypass pin, and the datasheet explicitly states: "Do not load the VDD18 pin with external circuitry." This restriction means the VDD18 pin is not designed to supply current to external components, including pull-up resistors for the PGOOD pin. Using it for such purposes could lead to improper operation or potential damage to the device.
For the PGOOD pin, the datasheet specifies that a pull-up resistor from a 1.6 V to 5.5 V supply is required. Suitable options for this pull-up source include the INTVCC (internal 3 V LDO regulator bypass pin) or an external supply within the specified voltage range. Ensure the pull-up resistor value is appropriate for your design, typically ranging from 10 kΩ to 100 kΩ, depending on the application requirements.
Harshal
