I am making a project to control a boost converter for a battery discharging circuit and I picked the LT8210 as it can handle input current limit (which I will program with AD5245). While reading the datasheet and choosing the components I found the formula for calculating CIN "for buck operation". Do I need a CIN if I want to make a boost converter? It doesn't specify anything about that in the datasheet. If so, which would be the formula?
Also, for the output capacitor I obtained 10.89 uF but I see in the examples there is an electrolytic capacitor and a ceramic capacitor. So 10.89 uF has to be divided into two capacitors or both capacitors should have the same value? Same question if it applies for CIN.
Thanks.
Carlos
