Clarification on VPRG1, VPRG2 pin configuration for resistor divider feedback control.
Product Number: LTC7138
Hello there,
 I'm planning to use LTC7138 with resistor divider feedback control.
While I checked the datasheet, Fig 6 mentioned VPRG1, VPRG2 to connect to GND.
But in the application section figure 11, VPRG1 connects to SS (Which is supposed to be a 5V fixed configuration).
Kindly suggest which configuration to follow for the external voltage divider based VFB method. Thanks heaps!
    It depends on what output voltage the chip will be used to generate. For high output voltages (>10V), it is recommended to use the schematic in Figure 11, where the Vfb is set to the fixed 5V configuration, and then external resistors are added to adjust the output voltage to a voltage above 5V. Otherwise, the schematic in Figure 6 can be used.
    Thanks!
