KCC Quizzes AQQ303 about the radius of a circle
1. Quote of the month: "When I die, I want to die like my grandfather who died peacefully in his sleep. Not screaming like all the passengers in his car" - Will Rogers
2. Quiz AQQ304 about finding the radius of a circle
Good luck, and try to be
August Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Important: Read the blog first . The quiz questions are all based on the content of the blog:
Stay in the loop and win! Read the blog Current Output Driving Industrial Loops , then take our quick five-question quiz for a chance to win a gift card
| SLA Status | Assignee | Support Status |
| ⚠ 6852 hours | Open | |
LTC7000A
Recommended for New Designs
The LTC7000A/LTC7000A-1 is a fast high side N-channel MOSFET gate driver that operates from input voltages up to 135V. It contains an internal charge pump...
Datasheet
LTC7000A on Analog.com
LTC7000A datasheet suggests that it works for the wide input range of 3.5V to 135V Vin. But in my application, I am facing an issue with the MOSFET switching at lower voltages. In my design I have four of the driver and MOSFET circuits, two 12V and two 5V. The circuits with the 12V are working fine but the 5V circuits are not switching. I need to control Power supplies to 4 different loads ranging from 1A to 6A. I have observed the voltages on BST (9.18V w.r.to GND) and TS (1.62V w.r.to GND). Tried changing the BST-TS capacitor but the output is still the same. Tried replacing the MOSFETs and LTC7000A chips with the new ones suspecting the damage, but still the same outcome. The Voltage on VCC pin is 4.5V, I also tried shorting this pin to Vin 5V suspecting the lower voltage. Could someone suggest where I am doing wrong and guide me to resolve this issue? I am attaching the schematic file for reference.
