We are using LTC7871 as a 6 phase Buck converter set to CCM mode .
Input is 100V max, 60 A
Output expected 40 to 78V adjustable.
Since LTC sense pins cannot handle voltage more than 60V above ground, the LTC7871 is made to float above ground voltage, while ensuring that SNS pins do not go below Ground of the LTC or exceed 60 V. Same with V high pins etc.
Inductor used in each phase is 47 uH DCR is 12 milli ohm. Inductor Inductor Saturation current is 28A . Switching frequency is set to 100 kHz
Current sense resistor used is 2 milliohm , and the I lim Pin is set at V5 ( i.e 50 mV )
The current sense circuit filter R & C are set as per calculation given in datasheet.
The circuit works well up to total input current of 30 A , both in current limit mode by varying voltage on SETCUR pin. and also in Voltage loop mode by varying feedback to VFBlow pin.
Our problem is that duty cycle does not go beyond 65% once input current reaches 30 A, even if we reduce VFBlow to 1 V or increase voltage on SETCUR pin.
The Imon pin shows only 1.45 V
Current limit is not triggered and the behavior is same with current sense resistors of 3 milliohm value.
My observation is that the SS Pin voltage drops to 1V from normal value of 2.5 V , the instant 30A input current is reached.
I am able to increase output voltage / duty cycle by reducing the load, as long as I do not exceed 30 A input current.
Kindly advise solution, and reason for SS pin voltage dropping down.
Also what is to be done with ITH high pin and VFB high Pins ? for a Buck only configuration ?
Regards
Aniruddha Gandhi
