LTC4235_What is the judgment voltage (mV) when IN < SENCE+ (reverse current) with ideal Di?
Category: Datasheet/Specs
Product Number: LTC4235
The LTC4235 has two ideal diode controllers. What is the reverse current detection voltage (overdrive voltage) in mV?
From what I can see in the datasheet, it only says that if the input is shorted to GND or something else and reverse current flows through the load, the regulator will shut off to protect against reverse current.
