In my design I use SHDN with NMNOS transistor as describe:
When Q4-1 change to on/off the 24V_OUT1 rail is always 24V
SHDN = 0V when Q4-1 is 3.3V
SHDN = 2V when Q4-1 is 0V
KCC's Quizzes AQQ304 - A pure logic
1. Quote of the month: "I am not lazy, I'm just in energy-saving mode" - unknown
2. Quiz AQQ304 about finding a pure logic puzzle
Mike is looking at Anne, but Anne is looking at Paul.
Mike is married, but Paul is not.
Question:
Is a married
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
LTC4359
Recommended for New Designs
The LTC4359 is a positive high voltage ideal diode controller that drives an external N-channel MOSFET to replace a Schottky diode. It controls the forward...
Datasheet
LTC4359 on Analog.com
Q2 has probably failed due to exceeding the safe operating area (SOA).
Verify by measuring the resistance from gate to drain to source when the circuit is OFF.
Q2 must be selected to have enough SOA to survive startup.
Also, I recommend not straying too far from fig 6 in the datasheet.
The 1kΩ on VSS is necessary.
Why Q2 SOA is not enough to survive startup ?
1K ohm on VSS is not for reverse voltage protection ?
