LT3086 as Voltage Limiter
Product Number: LT3086
I am looking at the use of the LT3086 as a voltage limiter. We have a product which can operate from up to 24V but with an input which can be above or below that by a few volts.
Clearly, as a voltage regulator it can regulate its output to 24V if the input exceeds 24V plus the dropout voltage. But if the input supply falls below the LT3086's set voltage, will it simply act as a pass-through, subtracting only the dropout voltage from its output? Obviously, in this state we do not expect it to be regulating.
  • In general these LDOs recover relatively quickly either going into or coming out of dropout, so it is reasonable to use the LT3086 as a voltage limiter as you suggest.  If VIN goes below VOUT, the LT3086 may shut off because of the reverse current protection, but that should not be a problem since that means the output is held up anyway and the LT3086 will turn on quickly.  You can evaluate the behavior in LTspice or order yourself demonstration circuit DC1729A.
    LT3086 ferrite load_2.asc
